-   -   throttle plates, intake manifold are coated with a brown /tar/molassis (https://www.offshoreonly.com/forums/general-q/235293-throttle-plates-intake-manifold-coated-brown-tar-molassis.html)
fountainfan42 07-22-2010 01:30 PM
Bottom of throttle plates, intake manifold,intake runners are all coated with a brown /tar/molassis
Fuel tank was re-done last winter with base coat AT primer #2 made by REICOLD & then Vinylester Resin Dera Kane Model 510 M runs thru 2 filters and then to the motor .fuel was 93 octane added to tanks 3 weeks after coating problem arose after fuel sat over the winter mos ... fuel was STA-BIl ized and still looks good ,i have taken a sample of the fuel & boiled it and the same tar residue appeared has anyone had any similar chemical reactions like this ??? I know it would be easy to pump the tank & start with fresh fuel but will it do it again & again & again
what ya thinkin Cat Lloyd ?:drink:
FIXX 07-22-2010 02:28 PM
Fixx
are you sure no body stuck brown sugar in your tank??
fountainfan42 07-22-2010 02:40 PM
No Sir , boat is in my locked & alarmed garage & i filled it
