-   -   502 MPI Tach Issue (https://www.offshoreonly.com/forums/general-q/235335-502-mpi-tach-issue.html)
Wilks 07-22-2010 11:21 PM
502 MPI Tach Issue
I have twin 502MPI's. The RH tach gitters above 4,000 rpm. below that it is rock solid. The engine runs fine but the tach gitters around 200-300 rpm. I switched tachs left to right and the problem stayed on the right. I have checked grounds and power and all seems correct. Any ideas?
Ted G 07-23-2010 08:04 AM
Swap distributors and see if it follows. I have seen the tach start to jitter at high rpms from a loose distributor shaft. Eventually it gets worse and the engine starts to miss too.
