-   -   Spark Plug Difference? (https://www.offshoreonly.com/forums/general-q/23542-spark-plug-difference.html)
29Fever 05-02-2002 02:46 PM
OK, I know the Rapid Fire #1 and AC Delco MR43T thing was just done, but I have a question. Yesterday I went to Pep Boys to buy the Rapid Fire #1s. They were out of stock, but they said the price was $3.99 each. Today I went to Autozone and they don't carry the Rapid Fires. I got the AC Delco R43T for $1.60 each. I guess my question is what is the difference between between a $4.00 plug and a $1.60 plug? Also is there a difference between the R43T and the MR43T. Obviously the M stands for marine, but is there really a difference?
Should I just be happy that I saved some cash or should I get the better performing plugs?
1998 500HP carb. Thanks.
1Boatnut 05-02-2002 03:21 PM
I know the biggest difference is the rapid fire has a longer nose reaching further into the cylinder,causing for a hotter spark advantage. I put the #1 in my boat last year and they were difinately worth the money
Dean Ferry 05-02-2002 03:24 PM
Tim,
I don't know, I went in looking for a MR43T also, and walked out with the RF#1. The "M" is for Marine, and I think that makes the the Sp. Plug corrision resistant, (I have never had a corrision problem myself, I always install them with Elec. grease on them), I can't really say how they will run, give them a try, if you don't like them, at least you didn't spend alot of money!:cool: I bet them will run fine.
MD
baja27 05-02-2002 03:39 PM
Longer tip, won't rust, plantinum tip last a lot longer. Will burn cleaner than standard plug. Worth the money.:)
jdnca1 05-02-2002 04:09 PM
Tim;
$2.40 is the difference. When Pro stock starts running platinum tipped plugs I'll change my mind. Now if you want to put in a set for 1000 hrs then go with the platinums.. :cool: I run NGK 5672A-10 or Champion Pn#791 in my Natural 632. Where do you keep your boat? I put in at Rivertown.
kaamacat 05-02-2002 04:56 PM
29Fever.....The MR43T is the marine version (ss base) versus the R43T. I think the MR43TS is more similar to a RapidFire as an extended tip plug. (the RF may have a platinum tip area, not sure). I've also read in a few places the the RapidFire is great for idle speed (helps with the transom soot), and runs cooler at higher rpms. I've not personally used the RF's because I have a std ignition setup, requiring a .035 gap. (the RF come at .045 and I though you were definately not supposed to close the gap on it).
29Fever 05-02-2002 05:23 PM
jdnca1,
I usually keep it at Captain's Cove West, but I'm expecting my first baby in a month or so. Needless to say there will be little boating this year. When we were planning I was looking for a way not to kill a boating season, but it just didn't work out. I'm hoping to sneak out here and there. It might be easier to just bum rides from my OSO brothers this Summer.
I think I'll just keep the AC plugs. Hell, it's what's in there now anyway.
1Boatnut 05-03-2002 09:23 AM
Tim, sorry I didn't state this in my 1st post. The A.C plugs you got would definately be the plug of choice after the #1 RF
MKast 05-03-2002 10:06 AM
I always wondered, if Rapid Fire plugs are desirable, why aren't the manufacturers using them? Both marine and auto.
To the best of my knowledge, it has a split electrode, big deal, the plug can only fire off the one electrode.
I'd like to be enlightened.
jr 05-03-2002 01:42 PM
MKAST, I work in the auto industry. I'll bet you the reason is cost. If they can use a plug that costs them 50 cents vs. 1.50 and they get acceptable performance, in their eyes. They'll go the cheaper route. Think about this. 1 dollar savings per plug, 8 plugs per vehicle. 8 bucks a vehicle times 3 million vehicles. That doesn't add up to chump change. And thats only in plugs.
The record profits automakers were making a couple years ago were partly due to reducing content and parts within vehicles. In some cases extra things are added in so someone can look like a hero when they are removed a year later and they save a couple million.
MKast 05-03-2002 02:04 PM
Hi jr,
I understand your point, I agree with it. My question was, why are you guys spending your money on a gimmick plug? Remember the FIRE INJECTOR plugs?
I ran a set of RFs once, had no difference in idle, performance or economy. Someone noted the extended electrode, Motorcraft has been running that extended tip for over thirty years.
I find it hard to believe a RF costs any more to manufacture than an AC plug. I can believe with slick marketing I can increase the retail cost by 400%. Remember, this is "Pet Rock Country".
1Boatnut 05-04-2002 05:03 PM
There is a article in April 2000 hotboat on pg. 102 that explains the difference in plugs. What I was trying to explain in a earlier post is the AC Delco rapid fire is a protruded tip plug and has the ground strap narrowed down over the electrode,unshrouding it and allowing it to come up to temperature quicker.
I hope this helps. If anyone has this copy of HotBoat,it is a great article with many helpful hints.
It is called Engine Tuning for Maxiumn Performance
GameOver 05-04-2002 05:06 PM
I hear about everyone changing there plugs once/twice a season. Even though $2 a plug is nothing compared to the other costs of maintaining a boat, I feel better throwing away a $2 good plug vs a $4 good plug.
HARRISONMIRAGE 05-05-2002 01:05 PM
ARE YOU SURE THE OLD PLUGS WERN'T R43'S.THE MR43'S ARE MARINE VERSION.THE ONLY DIFFERENCE BEING THAT THEY ARE PLATED AND THE PORCELIN IS A BIT SHORTER FOR MANIFOLD CLEARANCE.
