496 mag antifreeze leak
Need some help please, Noticed antifreeze in bilge,
reilled antifreeze and noticed small amount of oil film floating in bottle. ( cant see leak any where ) Took it to a shop for repair , they said the pump was leaking. They changed the pump , (why the oil in bottle ) took the boat out ran it at 4000 rpm for a few min. and checked it , the antifreeze is back in the bilge again and the oil film is floating in bottle when i refilled it. Will be back at shop monday. Any ideas ? Rick |
Originally Posted by Fountain4402
(Post 3167301)
Check all hoses and connections, or head gasket is blown. check the thermostat as well.
(Post 3167301)
what would make it leak and where? maybe soft plug ? I cant see where its comming from. It seems to be in the area between the bottle and the pump. |
Had a leak on my 496 for a full season,finaly the hose to the water pump blew up antifreez everywhere,,replaced$1.25 clamp.
Got the boat fixed it was a rubber seal on a
heat exchanger hose. I just want to say thanks to simmons marine / simmons racing in franklin ohio /akron, for the excellant job on the repairs. Thanks again Jim for the great job. Rick |
Rick that still does not explain the oil in the bottle.
I had it check out and it wasnt oil , it was
something from the heat exchanger. my mistake, am I glad ! |
Originally Posted by brian41
(Post 3171343)
( simmons racing ) did you see them ? I thought you were there. |
