496 HO popping at 4000 rpms
We have a 36 Outlaw with twin 496 HO's. When we get to about 4000 rpms, I hear a popping sound coming from one of the motors. The rpms didn't drop a noticable amount, just he popping sound. I couldn't tell which one was actually making the noise while driving the boat. The motors have about 140 hrs on them and run great otherwise. Any thoughts on what is causing this issue?
Originally Posted by mpally
(Post 3167664)
I had the same problem this year when I put the boat in for the first run of the year, when you pushed the throttles and she was under a load it would pop and lose power. Turned out to be corroded rotor & distributor cap.
mine started yesterday ! i can be at 4500 rpm with throttles half way.. and no sound.. the minute i push further , the popping starts. if i let go the throttle a little, it is perfect... only under load at 4500 + ... any ideas ?
Originally Posted by J.B. Marshall
(Post 3167922)
(Post 3167664)
This will turn out to be a bad plug or plug wire.. If plugs are over a couple years old then try that first..
Chris |
I had the same issue with a 305mpi in my old Crowline. I replaced all the sparkplugs and wires and never had another problem.
My boat is at the shop for the same thing.
| All times are GMT -5. The time now is 08:00 AM. |
