-   -   In a bind with Trailer Trim (https://www.offshoreonly.com/forums/general-q/235851-bind-trailer-trim.html)
aven2rus 07-30-2010 09:11 AM
Getting ready for the weekend and went to trim the drive up and nothing using the trailer trim.
Motor trim works fine. But trailer trim nothing?
I had moved the pump of to the side to fefinsh the floor yesterday and it di tip on its side for a moment.
However after reinstallation I trimed it down to install a drive shower and now it will not trailer trim, only the running trim.
rchevelle71 07-30-2010 09:19 AM
Is the solenoid clicking? Did it leak Fluid?
If the solenoid is not working, clean wire connections and retry. If this still does not work, and you cant find a replacement right away you can jump it with a screwdriver or wire jumper like a starter solenoid.
Ebay Ed 07-30-2010 09:37 AM
check the plug for the wiring mine did the same thing a while back unplugged it and plugged it back in no problems since
aven2rus 07-30-2010 09:56 AM
Ok Dumb A$$ here with a new boat.
After pulling the switch panel and using my test light I found the purple from trim was power out for up and has a jumper to the trailer switch.
So I say to self how could it have power to the trailer if I don't have the other switch activated......ya hold both down...:lolhit:
First boat that the trim was not on the handle (dual controld) so guess that is a safety so you don't activate the trailer trim runnig.
Irishtornado 07-30-2010 12:29 PM
Trim limit switch stops it then you have to push both switches.
Ebay Ed 07-30-2010 02:43 PM
i didnt even think about you not pushing both buttons together LOL
