-   -   Raw Water Pump (https://www.offshoreonly.com/forums/general-q/235903-raw-water-pump.html)
Robertjr 07-31-2010 07:31 AM
Raw Water Pump
Who has the best price on 2-piece Merc water pumps? I have found 110.00 for the housing,impeller,wear plates and gaskets. I am aware of the newer 1-piece design, but that wont work in my application due to the fact the engine mount plate interferes with the 1-piece hose connections. I no longer have the parts connection I once had, .................................Robertjr......... ..........................
Robertjr 08-02-2010 11:22 PM
bump
picklenjim 08-03-2010 12:23 AM
I thought the 2 piece were discontinued. All I ever see anymore are the new one piece ones. I converted mine to the one piece and thought they were dimensionally the same. If you can find a 2 piece you better grab it what ever the price if that's what you need. In fact I just looked and the plastic impeller body for the 2 piece is NLA from Merc. That's probably why that one you found for $110 is so high. That's crazy. You can get a 1 piece complete kit for $47. You sure that won't work? http://cgi.ebay.com/Mercruiser-Bravo...aultDomainQ5f0
Robertjr 08-03-2010 12:41 PM
No the new one piece wont fit, the hose connections hit the "Offshore" style front motor plate on my boat. Its too late for a re-rig considering theres only about 10-12 more weekends available. And who knows I may miss some due to work projects on the horizon. Another thing, doesn'the multi- stage raw water pumps that are available from KE and Hardin use the center sections from the 2-piece design?............................Robertjr....... ...............................
picklenjim 08-03-2010 01:19 PM
Don't know about the multi stage ones but it does look like they have the one you need. http://www.hardin-marine.com/detail~ID~643.aspx
Robertjr 08-03-2010 03:44 PM
Hey Thanks! I found that one as well, I'm still searching suppliers..............................Robertjr... .......................
SkiDoc 08-03-2010 09:28 PM
I get mine from Teague. Did you call them?
Griff 08-03-2010 10:33 PM
If you have the metal housing, it is much better than the plastic one piece and doesn't need to be replaced nearly as much. You can just get the kit without the housing for about $50. Merc part number is 47-59362Q 7. The cheapest place I have found to get impeller stuff is at boatfix.com
http://boatfix.com/bykeywordmerc.asp...kit&texttype=2
