-   -   Tachs dead? (https://www.offshoreonly.com/forums/general-q/235920-tachs-dead.html)
OhioRiverCigarett 07-31-2010 01:06 PM
Tachs dead?
Can anyone point me where to look? Both of my tachs are dead? Seem odd that they both dead at the same time. I have Det Mar 6000 RPM tachs and Thunderbolt IV ignitions. Carb 454's.
I have 12.4 volt at the guage (Bat to ground)
and 12.4 signal to ground?
The tach doesn't move. How do I test the gauge?
Thanks for any help!
OhioRiverCigarett 07-31-2010 02:57 PM
Testing
How do you tell if the tach is just dead. I also have "sincr" meter.
Thanks for the help
rlj676 08-16-2010 08:49 PM
Hopefully you have solved your issue....
If not many voltmeters will do frequency as well. I think you could see if you're getting the signal at the tach then (at least that is what I just did......after checking every single other possible option). I haven't put in a new tach yet, but am fairly certain it is what is broken now.
There's info online on how to use a voltmeter as a home made tach which should help.
carter38 08-16-2010 09:05 PM
Check all grounds sounds like it's got to be something simple if they both went. I know it can be very frustrating. I just had one giving me fits I checked and checked ended up being bad connection in the cannon plug. Easy fix was just a headache.
