-   -   Removing Bravo III with DTS (https://www.offshoreonly.com/forums/general-q/236083-removing-bravo-iii-dts.html)
DORaymond 08-03-2010 09:25 AM
Do I have to manually shift the drive into forward via the cable in the bilge so that the claw disengages when I pull the drive? I believe that if I shift into forward with the ignition on, and then turn the ignition off, the computer will put it back into neutral and I won't be able to disconnect the drive.
Knot 4 Me 08-03-2010 09:33 AM
You do not shift Bravo Drives into forward to remove them as you would an Alpha drive.
