-   -   502 mag engine temp?? (https://www.offshoreonly.com/forums/general-q/236103-502-mag-engine-temp.html)
SLAZARZ 08-03-2010 12:32 PM
I just picked up a 1999 38zx with 502 mags.
both engines run between 170-180 deg. Is this considered normal range?
Thanks Scott
minxguy 08-04-2010 08:28 AM
My '99 454 runs 165-170.
Ken
SLAZARZ 08-19-2010 02:14 PM
anyone else?
onesickpantera 08-19-2010 02:33 PM
Mine ran about 150 and up to 160 after a hard run.
WR-1 08-19-2010 03:02 PM
mine are EFI's and run 170-180 ...I believe they should have 180 thermostats,
onesickpantera 08-19-2010 03:51 PM
I believe the 502 Mag should run 807252T2 which is a 160* thermostat. Mine may have run 160 and 170 after a hard run(it was a few brain cells ago) I know they didn't run 180 ever. Not saying good or bad, just saying.
Griff 08-19-2010 10:02 PM
My 502mpi's run 165-175 on the gauges. I wouldn't worry about 170-180* as long as they are consistent.
jjj 08-20-2010 07:12 AM
My 454 mpi with fwc runs 170-180 also(mostly just under 180)
DMAX 08-20-2010 09:00 AM
Thanks Scott
Thats where mine run also, when running hard, with 260 Oil temp . Than head way speed water temp. 155, 160.
Smitty 08-20-2010 07:12 PM
Might be time for new sea pump impellers.
SLAZARZ 08-23-2010 09:06 AM
new impellers when purchased last month
jimjomack 08-23-2010 07:13 PM
I have twin 502's in a Pantera, fresh water cooled. Temps are 180. Never had a problem
Harvey 08-24-2010 08:02 AM
170 temp
