valve cover breathing
454; holley 750; with edlebrock intake.
On my valve covers they each have a breather stack that emit fumes and I was considering a change to help with the smell in the boat. what do I do here? With new valve covers do I vent them back into the intake with pcv valve? If so can someone explain the proceedure ie; where does it enter the intake? Does the pcv valve need power? bascially how do I make this change. thanks much. |
You use 2 of these adapters connected to the top of your flame arrester.
http://www.cpperformance.com/p-14122...gle-mount.aspx |
so you are saying to vent the valve covers into the flame aresters?
Yes, or u can buy a catch can and mount it somwhere and run the fumes to it , just don't forget to drain it out once a while !!!!!
But dumping in to the flame arestor is comon and actually helps oiling the intake valves !! |
Yep. That's the way it's done.
Might want to get a couple of these also for a quick easy installation. Just be sure your new valve covers have a 1" breather hole. You can pull these out to add oil if needed.
http://www.cpperformance.com/p-13639...with-vent.aspx |
the merc HP500 used a pcv valve in the intake, you can do the same in the valve cover..works better than just venting to the flame arrester
+1
My 7.4 vented to the flame arrestor, but still got oil smell / flim in the engine bay. Converted to a PCV and smell / film is gone. |
can anyone show me a pcv system using the intake from the valve covers?
thanks |
1 Attachment(s)
Originally Posted by toolsinbox
(Post 3175388)
| All times are GMT -5. The time now is 12:43 PM. |
