-   -   502 Mag EFI (https://www.offshoreonly.com/forums/general-q/236451-502-mag-efi.html)
rasttus 08-09-2010 09:12 AM
502 Mag EFI
I have a 1996 502 mag efi with the vst tank
I am wanting to check the fuel pressures on the injection rail
What gauge kits do you use or What do I need to get hooked to the rail?
obnoxus 08-09-2010 09:15 AM
You can check it right at the schreader valve under the front of the intake mani
Ted G 08-09-2010 09:18 AM
A lot of auto parts stores will rent/lend you a fuel injection pressure tester. Screw it to the schrader valve like checking a tire.
rasttus 08-09-2010 09:40 AM
I didn't realize it was just a scrader valve
thanks for the replies
