-   -   Alpha One shift problem (https://www.offshoreonly.com/forums/general-q/236454-alpha-one-shift-problem.html)
porker99 08-09-2010 10:13 AM
I'm having problem with adjusting the lower unit shift cable for alpha one. I replace the outer & inner cable with no problem. The problem is I have the lower unit in full locked in forward gear and I can not get the brass piece to be 6" from center to center I can only get it to 6.5" b/c it at the end of the treads. So any info will help.
I have a pic that expanded it a little better but cant figure out how to insert here
picklenjim 08-09-2010 05:15 PM
Might want to try over on http://forums.iboats.com/
Lot of Alpha guys over there that can tell what you need to know. :drink:
FIXX 08-09-2010 05:31 PM
Fixx
did you bottom out the liner? if you dont have the liner all the way in the gimbal your measurement will be way off..
also if you dont have the shift foot lined up under the upper housing(speedo pick up is located ) it will be locked into gear..
