-   -   Oil? (https://www.offshoreonly.com/forums/general-q/237155-oil.html)
stopdropanroll 08-18-2010 05:47 PM
Oil?
I know this as been a subject beatin to death but I did do a search and most of the subject matter was for stock motors. So my question is what wieght oil should I be running in my 454 MAG w/whipple? Plan on sticking with Mobil 1 but want to know what wieght would be the best, air temp ranges from 60-90 with a 75-80 average typical Wiscosin weather.
Kyle
stopdropanroll 08-18-2010 05:49 PM
FWIW The previous owner ran Mobil 1 (not sure on the wieght) and motor has around 65 hrs.
apollard 08-18-2010 08:57 PM
15W50 or V-Twin 20W50
Griff 08-19-2010 01:26 AM
15w-50.
The V Twin is about twice the cost of regualr Mobil 1 and not as readily available in large quantities.
ezstriper 08-19-2010 06:20 AM
can't even find the 15w 50 around me.....
mike11 08-19-2010 07:52 AM
Choose an oil with lots of heavy metal eg. zinc it acts as a anti wear agent on internals. EPA limited the amount to be used in conventional oils. Racing oils will have more.
We run Valvoline VR1 20/50 in everything
stopdropanroll 08-20-2010 08:25 AM
Thanks guys, ended up going with Mobile 1 15W50 and made a spacer for my filter mount allowing me to run a bigger Mobile 1 filter 1qt I believe.
Rexx 08-20-2010 08:54 AM
Mobil 1 is excellent oil. Use it all the time in my cars. However, I have a slightly different approach when it comes to boats. My theory is to use cheaper heavy weight mineral oil and change it often. Reason for this, BBC engines are known for fuel dilution into the oil which reduce viscosity whether it is synthetic or mineral. Second reason and my main reason, you have a better chance at catching a failure until it turns into a big catastophic failure. The oil is the blood of your motor, think of it as routine blood tests. The bigger oil filter is a good idea too.
Rexx 08-20-2010 08:55 AM
Forgot to mention, I use castrol 20-50w.
stopdropanroll 08-20-2010 09:28 AM
I will be changing oil every 20hrs, I know what your saying about fuel in the oil, my setup is too rich and needs a better tune, I can smell the fuel in the old oil!
Rexx 08-20-2010 01:55 PM
But if you use mineral oil, you could change it every 15 hrs and it will save you money while having more frequent looks at the oil. Synthetic oils last a long time, but in a boat, too
much can go wrong with the oil between the longer periods of the synthetics. Maybe I'm overly cautious, just that I've lost rod bearings and main bearings far to often because I didn't pay close attention to what the oil was telling me.
