a/c question
When the compressor starts it kicks the breaker. It will cycle the first three or four times then it kick the breaker. Water is coming out of the thru hull. Any idea?
Weak or worn out breaker
Originally Posted by firehawkcat
(Post 3187238)
most likely compressor is gone..drawing way more amps at startup....depending how old the unit is if worth replacing the compressor...most of the time we replace the unit, can help you with that if needed, feel free to give me a call Rob 540-786-8111
It seems to be the breaker. It worked all night after I replace it.
Originally Posted by ezstriper
(Post 3187501)
used to be a marine air systems dealer for years, then they got bought out about 10 years ago....everything changed now been with mermaid for almost 10 years....glad it was only a breaker....Rob
| All times are GMT -5. The time now is 09:31 PM. |
