Scarab ignition issue
I have an 85 scarab two with twin 454, about 9.1 stoke 781 oval ports and slight upgrade cam over the 330 piece and still q jet thunderbolt 4.
Problem is the timing jumps around 3 degrees at idle and I set it at 36 total at 3200 rpm, this puts it at 12 at idle. One engine at 3 grand it barely misses like a small puff sound out the exhaust every once in a while. Also, the timing light on that engine at 3 grand misses badly hard to see the mark and does not fire at times. I have never been able to get these motors over 4 grand or 50 MPH, and the motor don't have 150 hours yet. Is it plugs? coil? the cap and rotors have about a hundred hours on them. Thanks, Tim |
Just checked cap and rotor look fine, pluge #1 ok but lean.
if it were me I would drop in a pair of aftermarket HEI dists, buy the vac advance block off and the wire ends and give that a try, cheaper than changing parts in the mercs..very reliable, been running one for several years now..works great !
I like the HEI idea, never tried the vac block off, what should total advance be?
Fixx
Originally Posted by TDSracing
(Post 3190438)
| All times are GMT -5. The time now is 09:19 AM. |
