-   -   Stainless Marine Gen III 5" tailpipe fitting specs pls? (https://www.offshoreonly.com/forums/general-q/237541-stainless-marine-gen-iii-5-tailpipe-fitting-specs-pls.html)
surmirage 08-24-2010 04:43 PM
Dear OSO members,
Does anyone have dimensions or fitting specs on the Stainless Marine Gen 3 with 5" stainless tailpipe? I emailed stainless marine but no reply yet. Wonder if the tailpipe angle will match the stock transom exhaust holes. Original motor was 7.4mpi with capt choice silencer . tks
fastdonzi 08-25-2010 09:38 AM
If the set you got was made to be a direct replacement for a stock merc setup then yes they'll fit. if your trying to use tailpipes that came from another setup like a trs with a tranny then you be buying a hole saw.
