-   -   timing on a procharged engine (https://www.offshoreonly.com/forums/general-q/238054-timing-procharged-engine.html)
outlaw 08-31-2010 12:01 PM
getting close to firing up my 502 procharged engine
and would like to hear/see some timing charts.
I'm using a Haltech E6X EMS
Turbojack 08-31-2010 05:32 PM
Compression? planned boost?
Jeff P31 08-31-2010 07:49 PM
32 total at 3500 rpm with 7lb of boost is what I run . :drink:
outlaw 09-01-2010 08:39 AM
8.4 :1 boost up to 10 max. target 8psi. 6200RPM
gen 6 block with JE pistons and AFR 325 CNC heads
cutler/Hirel manifold with 1000CFM throttle body, 96 lbs injectors
M3SC with a 12 rib ,this system was off a merc 525
I realize I'll need more advance at lower RPM's untill the boost
comes in. since it's a jet it will rev up from the hit.
http://i258.photobucket.com/albums/h...g?t=1283348898
