-   -   What would make Carb overflow when hot? (https://www.offshoreonly.com/forums/general-q/238152-what-would-make-carb-overflow-when-hot.html)
Thunderstruck 09-20-2010 07:22 PM
Of Course it could. I guess you did say in your first post that you had a 500 HP carb and not a carbed 500 HP. :grinser010:
See post #8 but look at vacuum at idle vs power valve opening vacuum.
HTRDLNCN 09-20-2010 08:07 PM
I have a vacuum/boost gauge but Vic Jr doesnt have any vacuum ports so I have to drill and tap for one. Guess thats my next weekend project ..
ezstriper 09-21-2010 06:15 AM
power valve would have no effect on gas leaking in thru tubes, has to be fuel level rising after shut down, either fuel pressure, needle/seats, floats, etc..power would leak thru baseplate....Rob
HTRDLNCN 09-23-2010 02:54 PM
thanks Rob..
RICHARD CUNY 09-23-2010 04:07 PM
My 850s both had the black floats and the epoxy that holds the weights in came off and the nedel and seat got cloged this year put metal floats in I beleve it was a fuel problem.
Rich
HTRDLNCN 09-23-2010 04:27 PM
Rich,before rebuild we did pull some unexplained crap out of needle and seat which was weird considering fuel filter was clean.
