Can't trim up but trailer works?
I just installed my 496 back into the boat and I noticed that the trim up isn't working yet the trailer trim is. I can trim down.
I think I have a connection that is incorrect or just not connected. I have been searching around on the harness but have yet to see the problem. It is a bit cramped and looks like a rats nest of wiring. Any step in the right direction is appreciated! |
Sounds like you have a problem with your limit switch, or maybe a fuse/switch connection.
Pair of black wires coming out of the transom plate for the trim limit switch.
Must have missed them |
Originally Posted by obnoxus
(Post 3198566)
The trailer mode bypasses the limit switch so it's prob in the limit switch or switc wiring
But you prob know that Disconnect 2 wires tcid:95499CFBD3EB413F8FAB5074ABF5B8CB@billPCo switch and put demon it and see if it shows open Then take and jumper wire to switch together see if it goes up |
thanks for the replies, guys! I will play with it in the morning. I know whatever it is will be minor
Mine was doing the exact same thing... The trim limit switch was all corroded and not making contact inside the switch. Took it apart, and with some WD-40 and scotchbrite, cleaned all the corrosion off and polished the contacts and whala, it worked again. Of course then you will have to readjust it. Good luck. Of course then my trim indicator switch started screwing up to and it was the same thing but much harder to clean and much more complicated. It still screws up every now and then.
| All times are GMT -5. The time now is 11:47 AM. |
