-   -   Distributor cap part # (https://www.offshoreonly.com/forums/general-q/23844-distributor-cap-part.html)
Jayl13 05-07-2002 09:13 AM
Need the part number for the 454-330 HP carb number in AC delco or the like with a rotor part number.
The automotive caps in the book dont match this thing
Is it off a small block or is it marine specific?
Just thought I could get the cap at NAPA or wherever instead of ordering it from somewhere
engine is a 1990 454
Jason
Jayl13 05-07-2002 10:50 AM
Also need oil filter numbers if anyone has them
What was the final outcome of the posts about what oil filter is good one to get and a crappy one?
Last I remember was Fram was changed and the way they are being built now is way lower grade than most of them
Anyone have any input?
Jason
Lee 05-07-2002 11:50 AM
Mercruiser Marine specific
Cap #805759T1
Rotor#13524t1
becareful when removing the screws in the distributor cap, they tend to seize and break if they have been on there for a while, use antisieze on them when reassembling
Jayl13 05-07-2002 11:52 AM
Lee, Thanks !!!!
Now what about the Oil Filter on this thing?
AC delco PF ???
(actually got a friend that works at a car dealer to get me the caps and rotors out of a auto catalogue)
All brass no aluminum stuff too
Thanks all
Jason
Strip Poker 388 05-07-2002 06:43 PM
oil
pf 25 is small one
pf35 is 1 quart one ,should fit
msd i think make a cap thats like thre merc
mark linger 05-28-2002 03:18 PM
cap
can you use a automotive distrbutor cap in a marine application?[and rotor?]
i just purchased a merc cap for $40.00,
if yes do you know what i should ask for,i have 1993 merc 502
Jayl13 05-28-2002 06:22 PM
No I found out that the marine dist cap is different and sits different so no, not interchangeable with automotive caps
Make sure you get brass caps and rotors to prevent corrosion, will last a little bit longer
Just bought 2 caps and rotors from Napa, and painted them magenta metal flake like the engines and accessories
Got taylor wires, MSD hi vibe coils and NGK spark plugs
Going to get this honey nice and hot
Jason
