496ho Blew Its Cookies
Saturday was a beautiful day on the water, for about an hour anyway! Was running from one end of the lake to the other and thought I would wind it up alittle, at around 4800 RPM "20 seconds" I felt the boat jerk and starboard motor was dropping RPM and stalled. Engine temp. was around 160 and oil pressure 45 PSI. I stopped right away and raised the engine hatch and noticed what seemed to be a small puff of steam belch out of the flame arrestor. I attemped to restart engine and had an uneven cranking RPM along with rattle every revolution. I checked the oil then and it was about 6 inches over full then found the coolant reservoir to empty.
I had read about weak pistons on the 496's on modified engines, has their been much of a problem on bone stockers with 40 hours? I am assuming the piston came apart and went through the cylinder wall. Are their certain year engines better than others? |
Anything can break,40 hours is it under warranty?
If so just take it to a mercury dealer.If it did break a piston they will more than likely chang the whole engine. Water in the oil and cylinders is either a catastrophic failure like piston puts hole in block.Or an exhaust issue and possible hydro lock. |
I think you are on the right track....have heard of injectors going bad or clogged..leaning out and killing pistons !!
If a piston broke up it would have gone out with a bang and would not crank over. Pull the plugs. See if one is damaged.
It happened so fast that the antifreeze pouring in the motor never mixed to a milkshake...I have not torn down yet, but with the un-even cranking RPM and deep rattle every cranking revolution it doesnt sound good...I am going to pull plugs and used a friends bore scope and find out....
2 Attachment(s)
If it is under warranty you are in luck.
If not... Pull your plugs. If one is chewed up you may as well pull that motor because the show is over. Check the #7 cylinder, a few other guys lost #7 including myself. More than likely a piston imploded then the connecting rod punched a hole in the cylinder wall and sucked the anti-freeze out. Since it sucked in oil & anti freeze at 4000RPM you probably bent a few rods as well. Here is what it will look like.... |
Sounds to me like you had a coolant leak in it and hydrolocked it. dont ask me how I know...:rolleyes: pull the plugs and drain all the oil and fluid and then get fresh oil back in it, even run it for a couple minutes with the belt off to get oil circulating, it could be a plethora of things from a gasket either head or intake to something more serious.
1 Attachment(s)
I just pulled the plugs and number 1 was smash!
Originally Posted by Keith Atlanta
(Post 3200668)
Originally Posted by xhere
(Post 3200881)
Any idea what is causing the failure....Cast or forged pistons?
I cant tell from your picture. Is that plug melted or a piece of aluminum stuck in there? |
| All times are GMT -5. The time now is 11:21 PM. |
