BBC help needed
Hi guys, just had the heads on my 454 machined as they were in a bit of a state and the machinist had to remove 25thou from both intake faces.
Can I get extra thick gaskets to make up the difference or is there another solution to this? Heads are cast iron Merc alpha oval port if it matters. |
Mr gasket makes double thick rect port gaskets they may have oval as well..ck with them
| All times are GMT -5. The time now is 04:38 AM. |
