-   -   MEFI 1 interface 10-pin cable (https://www.offshoreonly.com/forums/general-q/238640-mefi-1-interface-10-pin-cable.html)
bert4332 09-08-2010 12:13 PM
Anyone know where I can purchase one?
Griswald 09-08-2010 01:01 PM
Google Mouser Electronics
bert4332 09-08-2010 04:20 PM
I called, they couldn't help. :-(
Griswald 09-08-2010 05:36 PM
go to the website. I know I've seen some there. They have an entire section on the parts used for Delphi products.
bert4332 09-08-2010 08:24 PM
It's like a needle in a haystack, I can't seem to find the correct female connector.
Fever575 09-09-2010 11:30 AM
Try ODB they can point you to the web site that sells all the connectors.
Give them a call they are good guys to work with.
http://www.obd2allinone.com/sc/details.asp?item=mefi4b
Heatseeker 09-09-2010 02:08 PM
Are you looking for the connector that plugs the EFI harness into the MEFI 1? I think it is a 32 pin, not a 10 pin connector.
Try this link to get the part numbers you need:
http://connectors2.delphi.com/dcsgdm...100Wheader.pdf
This is for a MEFI 3, but I think the MEFI 1 uses the same connector (a Delphi Micro-Pack 100). Once you find the part numbers, search for them on the Mouser.com site. They should have everything you will need, and they ship very quickly.
If you are looking for the connector that connects the EFI harness to the charging harness, I believe it is a Delphi Metri-Pack 150 connector. I can get you info on that as well if you need it.
