305 0r 350
mercruiser small block, how can I tell which motor is in the boat, 305 or 350
Is there a serial number or horsepower rating on it anywhere?
Look for the casting numbers on the block.
most will have a fairly large 5.0 or 5.7 outcast on the block
usually looking down at the back of the block, I dont see it
If you can get the casting number of the head that might lead you in the right direction also. The 305s I have worked on had a smaller chamber heads. Several people used the 305 heads on stock car engines to raise the compression.
try looking on the block area on top at bellhousing area behind dist.
| All times are GMT -5. The time now is 01:58 PM. |
