-   -   Enderle or Hilborn Mechanical Fuel Injection Questions (https://www.offshoreonly.com/forums/general-q/238917-enderle-hilborn-mechanical-fuel-injection-questions.html)
marcg007 09-12-2010 06:56 PM
HI all, running a 96 scarab with a bbc 7.4. Just picked up a 671 dyers charger with an enderle incection hat. Intercooler also.
talking with enderle they state the fuel pump needs to be 7 GPM, Does anyone make a cam driven pump capable of producing 7 gpm that could replace the stock mercruiser?
Anyone have any tuning advise? or where i can get more advise on setup and tuning? low idle advise ??
take care....
FIXX 09-12-2010 08:11 PM
Fixx
take care....
we use to use a belt driven fuel pump for the mechanical injection, this is a mechanical and will deliver 450 GPH or 7.5 GPM. http://www.racepumps.com/index.html
AS for tuning your best be would be to tune i on a dyno,you will also need to install a return line in the boat's gas tank and not in the over flow hose..With that kind of pressure you will be dumping fuel in the lake if you use the over flow hose..
SHAWN DAVIS 09-13-2010 11:07 AM
I doubt you can get the mechanical fuel injection to work in this application. The Mechanical deal is a mostly on or off throttle, with poor part throttle fuel distribution and tuning. Trade it for some carbs.
Jim Craig 09-13-2010 12:17 PM
Nothing against mechanical injection (in a racing application) -- but I would avoid it like the plague in a cruiser, way too many issues.
Use the blower but convert it over to EFI -- both Hilborn and Kinsler (there are a few on this site that'll convert for you also)offer EFI conversions to be used on blowers. With this, you'll need to convert to an electric fuel pump with a bypass regulator that is returned to the tank -- or just put a set of carbs on it.
pat@osp 09-13-2010 04:33 PM
Jim Craig from Weldon?? Damn, I was surprised to see you over here...................shouldn't you be lurking around over on Yellow Bullet! :)
Pat at Ocean State Performance
ezstriper 09-14-2010 06:12 AM
you cannot buy enough tylenol to over come the headaches this is going to be !!
Jim Craig 09-14-2010 01:59 PM
Yes, it is...............I been over here for a while, you'd be surprised to see where and when I turn up. I'm just trying to help out where I can and stay out of the way where I need to.
and yes, as you, continue to lurk on the 'bullet................
I hope that all it well.
