-   -   Livorsi GPS Antenna "Yellowing".... (https://www.offshoreonly.com/forums/general-q/239241-livorsi-gps-antenna-yellowing.html)
X-Driver 09-16-2010 08:18 PM
My round plastic Livorsi GPS antenna is starting to discolor to a yellow color. Is there any product that will return it to white?
Thx-
Smitty 09-18-2010 08:39 PM
Unfortunately no.. The sun is changing the color due to UV rays. All you can do is paint it white or whatever other color you want.
CanDo 09-18-2010 08:51 PM
Yup...
just tape it off, and paint it. The paint won't discolor like the white plastic did. An appliance white epoxy spray from Lowes/Home Depot will do the trick.
Inspector 09-19-2010 07:06 PM
Yellowing may be the lease of your worries. I found out this summer that the Livorsi system uses an antenna with an internal battery that is not replaceable and only lasts 4-5 years. For only @ $200 they can sell you a new style antenna... if you have the correct vintage speedometer head. Good luck.
Turbojack 09-19-2010 08:14 PM
Do a search on here. There is a thread about how to go about replacing the battery.
INDY27 09-19-2010 08:23 PM
Just replaced the battery in mine, read this....
http://www.offshoreonly.com/forums/g...-speedo-3.html
