-   -   K plane ? (https://www.offshoreonly.com/forums/general-q/239505-k-plane.html)
baywatch 09-21-2010 07:40 PM
K plane ?
If I already have 280 k planes can I purchase two 380 lowers and attach (swap out lowers for the longer ones with out changing other stuff). Probably a dumb question but wasn't sure if they would match up. They are the merc tabs on a 1995 boat.
Sledge Hammer 09-21-2010 08:18 PM
Given the number of 280 plates only you see for sale in the swap section, I am betting you can.
Griff 09-22-2010 01:17 AM
That brick doesn't need bigger tabs:lolhit: It needs bigger HP:evilb::evilb:
But yes, 380 plates and 280 plates are interchangeable.
johnny b good 09-22-2010 05:42 AM
I have wondered about doing the same thing, what would be the main advantage someone would see on there boat going to the longer tabs?
Ted G 09-22-2010 07:57 AM
With a longer tab it provides more leverage so you don't have to put them down so much for the same effect. This means the boat will run a little faster at the same trim.
johnny b good 09-22-2010 08:12 AM
Thanks.......Makes sense
Knot 4 Me 09-22-2010 08:13 AM
Just be careful with the longer tabs and don't get too aggressive with them while running.
Ted G 09-22-2010 08:21 AM
We ran a 21 Hustler back in the 80's that had 380's on it. And there was a big sticker by the control that said something to the effect of "Trim Tabs should not be fully deflected at high speeds as an undesirable submarining effect may occur." :eek::eek::drink::drink:
zt260 09-22-2010 09:13 AM
I have swapped my 280 tabs the 380’s several years ago. All you have to do it swap the plates. It was a great improvement for me. Just watch out for the prop(s) hitting the tabs. I had to add limiters inside my hydraulic steering rams to prevent damage. I lost some low speed maneuverability around the dock, but the trade off is worth it if you run fast.
Knot 4 Me 09-22-2010 10:24 AM
Undesirable indeed! :drink:
AIR TIME 09-22-2010 06:25 PM
I bought mine for my baja with the shortie and plan on using rgem on the saber.
baywatch 09-22-2010 07:16 PM
where have you guys just purchased the lowers from?
THanks
Yes Griff, More HP would be good as well...
Griff 09-23-2010 01:39 PM
Once in a while there is a set in the classifieds. There is a complete 380 setup for sale in the swap shop.
http://www.offshoreonly.com/forums/s...trim-tabs.html
I am certain that your drives will hit the 380 plates when fully turned though and you really don't have any way to put in a stopper without hyd steering.
Back4More 09-23-2010 03:31 PM
I tried the 380 plates on my straight bottom 42 Fountain. They sucked. Way to sensitive to trim adjustments. I waited and thought I would get used to them after a full season but nope. Went back to the 280's. I think on a step bottom or even with horizontal mounting they work much better.
And yes they will hit. My drives are on IMCO boxes and I still had to trim them 2".
First Gun 09-23-2010 03:45 PM
And yes they will hit. My drives are on IMCO boxes and I still had to trim them a 2".
Wanna sell em ?:party-smiley-004:
Back4More 09-23-2010 05:58 PM
Sorry...Long gone. They went on a 94 38 TopGun with #3's
redbud35 09-23-2010 07:20 PM
Josh, if you get rid of the 280's I may have a place for them.
baywatch 09-23-2010 08:11 PM
I'll let you know what I end up doing..
baywatch 09-23-2010 08:13 PM
steering is on the list as well. I figure I will have to trim the 380's since I have a an 8'beam and side by sides.
Griff 09-24-2010 01:45 AM
With you current stock steering, you would have to cut off more of the plates than if you had hyd. steering.
The stock system allows the drives to turn a lot more than hyd. steering does. Probably 2-3 inches more.
