mercruiser pulley
I need at least one Merc. circ pump pulley for 454. It is part # 19692 3 groove steel apx 7" . I found a replacement from ebasicpower.com, but it is 6" . Does anybody know where to get these from. I can get all the other pulleys from Mercruiserparts.com but this one is not availiable. Around 88 Mercruiser changed their pulleys. The newer arrangement had an aluminum crank pulley, Alum seawater pump pulley, and a 3 groove Circulating pump pulley. I like to use the newer setup because the old steel crank pulleys all rot out. I will be building several motors in the near future and would appreaciate it if I could get any of these pulleys. The crank pulley is # 90081-C. Seawater pump pulley is # 52822-C . Thanks,
Big Block Billy |
Did you try pt# 19692P from Mercparts? It still shows good.
I tried by motor # and the part showed but was grayed out,
Mercruiserparts showed a price over $300, but it was not currrently avail. Maybe if I use the number in the search I'll have better luck. Thanks, BBB |
i think i have one off a 1989 365 mag,let me know
Originally posted by bbb242 I tried by motor # and the part showed but was grayed out, Mercruiserparts showed a price over $300, but it was not currrently avail. Maybe if I use the number in the search I'll have better luck. Thanks, BBB Naw, that ain't right. Try again .........Item #14, http://www.mercruiserparts.com/Show_...ND+FRONT+COVER |
Thanks US1 Fountain ! I typed in the number you gave me and it came up. Only $61 ! How cool is that. I'll be making my order tomorrow. Thanks again, BBB:cool: :cool: :cool:
Your more than welcome.
Just a thought...
I still have my original pulleys for this engine. I took a look at them through the dust to find the following part #'s: Waterpump: Steel 7" Sea Water: Alum. 5 5/8" #52822-c Crank: Alum. 6 3/4" #90081-c Alternator: Steel 2 3/4" w/ fan I ended up moving into a set of Alum. last year and couldn't see throwing away anything good. If you have a contact to get rid of these or a set of manifolds, risers, "Y" pipe, distributor, I would be appreciated. I would like to get them to someone that can use them... Thanks, Tim |
Red Racer, do you still have the 90081-c?
Where did you get your alum pulleys from Im going threw my motor and need the whole set.
| All times are GMT -5. The time now is 09:11 AM. |
