nitrous HP performance
Anyone have any knowledge on how long a 10lb bottle of nitrous might last (button time) 100-125HP boost on stock HP500. Maybe 3 minutes?
How many rpms would that gain , so i can determine what prop to run to stay in powerband with and without nitrous. Thought if i would only need it 5-6 times a year to play with someone,wouldn't that be better than running a blower 100% of the time for ware and tear? and no $5-8,000 cost. Boat runs fast enough for a thrill without ,but always those coulpe you'd like to stay up with once an awhile. Runs 85 then to maybe low 90's ?? Thanks,Randy |
I'm gonna take the first stab at this....and In my opinion (we run loads of sauce in our drag/street car), I dont believe youll be able to prop for "both". When your not on the spray, and have prop "A" on for all around performance, your boat will be fine. Turn the bottle on, and youll prolly hit the rev limiter...or be turning way more rpm's than that prop can handle. Now, lets put prop "B" on...cause thats the one the bottle likes...and now your all around performance suffers greatly. You could live with one or the other...but as I said, I dont think you can prop for both. On average...a 10 lb bottle (depends where you get them filled) is around $50 - $60. Then youll get addicted to it, and the next thing you know....your not feeding the dog, youve tried auctioning off your kids, and the lights have been turned off at your house for 2 months. Alllllll to quench the addiction of the "magic mist".
Oh...and pray nothing goes wrong in your motor while on the bottle....cause the damage is devastating sir. :drink: |
no offense, but by your wording and question on bottle life, my guess is you don't have a lot of experience with nitrous, so forget this idea. i've g
have 18 years of nitrous racing heads up stuff. with out typing out a novel on everything that's going to happen, what you need to do, what your going to fight, etc, i'll just some it up by saying if you want to give it a try i'd have a back up motor. |
I agree with NXFirebird. If it was the "hot ticket"...everybody would be running it. :boat:
Oh...and by the way...you saying your only gonna use it 5 or 6 TIMES A YEAR is like saying "the fat girl can stay outta the cookies"...lol. :drink: |
Thanks,guys,have a little use with nitrous on 2 cycle motors and have never blown one up in 20 years? Gained 1,000 rpm on most of them?
Prop wise i was thinking 5,000 rpm with no bottle and maybe 5,5-5,800 with bottle, turns 5,100 rpms now with out,works good? Got to make sure mixture is right and good solenoids? Just thought a light load of juice wouldn't raise rpm to much,eat to much up from bottle or damage engine if we make sure gas side is enough? Thanks for the in put ! |
Originally Posted by tinman565
(Post 3217279)
Oh...and by the way...you saying your only gonna use it 5 or 6 TIMES A YEAR is like saying "the fat girl can stay outta the cookies"...lol. :drink: Never really needed it only once and awhile,how offten do you run into a really fast boat (i know depends where you are). Thanks again ,just a wild thought ! |
i've bottled everything from a mo-ped to muli-stage outlaw 10.5 cars, i'd do it in a drag boat, but not a powerboat.
by a blower, you'll be really happy. |
something to try on your 2 stroke sleds, 1 quart of RC nitro to 5 gallons of avgas.... works all sorts stupid in banshee's...
As a former boat drag racer, I will tell you that there is no other engine "additive" except nitromethane, for adding torque and horsepower. However, drag boats run through the quarter in (my case) 9 seconds or less.
A 10/15 lb. bottle will last 5 to 10 passes, depending on how many stages and horsepower a given application has. So if you do that math, a 10 lb. bottle would last 90 seconds on a mild (100HP) system. Even if you got the proping and afr tuned to where it didn't hurt your motor, that won't work on a offshore/poker run boat. You'll have something that works for a short period of time and distance, which is why N20 is perfect for drag racing, but totally impractical for offshore performance boats. Our "races" if you will, are long runs between card pickups, and long distance lake races where the first guy who crys uncle loses. You are better off adding a mild supercharger, and that way you have extra boost all the time. Superchargers have come a long way and should not be hard on your motor if it's built with forged internals. Regards, Steve |
Thanks, Steve and NXfirebird
I was national high points champion in modified eliminator and st. louis drag boat points champion 2 times. MRA quad unlimited ice race champion New york snow mobile grass drag champion Michigan grass drag champion Done a little drag racing myself. You guys are absolutely right ,i'd be happier with blower. As most have said , i need to put better head gaskets on the motor if going to a blower. Do i really need to if it has only 50 hours on a HP500 and put a whimple charger with 5-6 ibs? I know just a matter of knowing its ok with better head gaskets. Thanks for talking some sense into me on spending the money. Randy |
I put a system on a twin engine Formula, picked up about 10 mph w a 125 kit. I think around two munutes total run time w twin 15 lb bottles.
Ran good no problems had good filters on all the solenoids to keep trash out. |
Fixx
Originally Posted by nxfirebird
(Post 3217264)
I have thought about NOS before, you would need a controller to keep the drive together. On my boat I have wideband O2 and a Holley MPI kit to adjust the mixture. Right now I run 74@5200 on the GPS and I can easily spin it up to 5600. I figured it would cost about $1k to set it up correctly. If it was only used 5 or 6 times you could probably get by on one bottle a season. Unfortunatlly I will not be doing anything else to the boat untill business picks up. Twin Turbo, or supercharger would be better.
Originally Posted by jeffswav
(Post 3217860)
thanks |
Originally Posted by mrfixxall
(Post 3217385)
you race the pro edelbrock class?
i ran super street in an old group call MSRA, and limited 10.5 at the outlaw 1/8 mile stuf,. we also had a car in ez street and drag radial. used to think that stuff was expensive til i got a boat!:lolhit: |
Originally Posted by SHAWN DAVIS
(Post 3217379)
Ran good no problems had good filters on all the solenoids to keep trash out. what did ya do about bottle pressure droping on 2 min? |
Originally Posted by Strip Poker 388
(Post 3217977)
(Post 3217977)
If your going 70mph then hit button for 10 seconds you can travel a long way to see whos faster ,count to 10 its a long full throttle. unless were off shore racing or poker runs of which we all know nitrous would be stupid for that? |
Originally Posted by r015
(Post 3217964)
Yeah i know what you mean, running 85@5100rpm so ,thought add 4-500 with nos ,rev is at 5,600rpm ,would the drive really be hit that hard at 4-500rpm when you only hit it at 70 plus?? Maybe get low ninties,wouldn't use in rough waters or long runs,just a short race 8-10 sec.or radar run.
thanks |
| All times are GMT -5. The time now is 09:34 PM. |
