Anyone have an Indmar 6.0?
I'm interested in marinizing a GM LS1 or LQ series motor.
Indmar uses these motors and has a crank pulley mounted water pump, which I would like to use too.
Has anyone seen how these are mounted? The standard LS/LQ pulleys dont have any provision for bolt holes, so I'm assuming they use an aftermarket pulley. But I cant find a close up pic or a part listing online.
I had a Ski Nautique with a Pleasure Craft Marine 6L. They use a slick pump mounted to the head where it is easy to service. Call Discount Inboard Marine in South Carolina. They have a website. They know the Indmars and PCM's inside and out. They will help you get what you need.
I'm Building 87 Chris Craft That I put a 5.7 LS1 in . I currently Have a Alpha but am going to want to go bravo soon which will require the Sea Pump . PCM Marine is Who uses alot of 5.7 , and 6.0 .
Look up Tige' .
Look up Tige' .
