fuel burn per hour
I need some help from all of you experienced guys. I am wondering what kind of fuel burn per hour you could expect from this boat
http://www.offshoreonly.com/classifi...o36151-en.html at 60 mph which should be easily in it's sweet spot for just cruising around. I am trying to do some calculations for possible distance/range. I am new to the bigger go fast boats and know that it will be an educated guess at best. Thanks in advance for any help given!!! |
Gotta be honest, and no offense, but if you are new to higher performance boats I am not sure this is the one for you- 120 mph cats are normally not the best boats to learn on, find a stable deep vee that runs in the 70's and move to the higher speeds later! Had a friend killed about 15 yrs ago, bought a boat he shouldnt have based on his inexperience with fast boats, said ill just cruise in it until i know what i am doing, had a few beers one night and lost control at full throttle, died instantly.
I agree 100% with GFS !!!!!!
but i also tell u with twin 700+ procharged 500's it will be about 2.5 gallons per mile !!!! :party-smiley-004: |
That boat falls into the category that if you have to ask about gas mileage, then it is not for you.
Between $hitty and REAL $hitty
Figure .5 lbs fuel per hour HP. Use max HP at WOT....best guess at cruise. Gas is about 6.5-7 lbs gal. If you run out of gas before you get back to dock, rework your HP estimate :drink:
Its only money
If you're worried about gas then this boat is not for you!
Just my 02 Cents :lolhit: |
50 Gph @ 60 .....
Buying gas will be the cheapest part of owning a boat like this by far!!!!!!
I hope you realize that fuel will be about least expensive thing on that boat.
If you are new to bigger go fast boats, NOBODY is going to insure you in a 120mph cat and you shouldn't be driving one anyway. BTW, 50-60GPH at cruise speeds. |
I had Procharged 500's in a V-hull. That 50gph isn't far off. Insurance for non-cat experienced driver will cost more than the fuel you burn all year.
My 31 Cig Bullet burns 40 GPH w/ 575 HP each. My boat is for sale and could be a great boat for you!!!!
Thanks for the replies. Right now I'm just doing some research for a possible "project".
The owner of the boat pm'd me with some info. |
Between $hitty and REAL $hitty |
Originally Posted by kreed
(Post 3219293)
I just filled up last night.....and did calculations that I probably shouldn't have.:drink: I went 136 miles (95% of this was 3600-4000rpm's) in a 38 Cigarette with 800's I burned 171 gallons That is .8 mpg...or 1.25 gallons per mile 70 gallons of AvGas @ $4.70 per=$330 101 gallons of 93 octane @ $3.279 per= $330 So, that's $660 to go 136 miles for a grand total per mile of .....................$4.85 per mile. Like everyone else has said, the gas isn't the expensive part.....breaking chit is and everything breaks eventually.........if you use it :) |
Last Saturday Long Is Sound
My 382 was probably the slowest and nearly the only powerboat boat out there Saturday afternoon. Sea's were 3's an occasional 5. I trimmed 3 down backed off to 30 MPH and had a fairly soft ride. My Granddaughter was asleep in the back seat so I wasn't going to get crazy but I couldn't help but wonder what the ride would have been like at 50 - 60. One of you guys must know.
P.S. I am the slowest guy on the highway too. |
My apologies I meant the above to be a new topic
Originally Posted by OldSchool
(Post 3219366)
:D
I just filled up last night.....and did calculations that I probably shouldn't have.:drink: I went 136 miles (95% of this was 3600-4000rpm's) in a 38 Cigarette with 800's I burned 171 gallons That is .8 mpg...or 1.25 gallons per mile |
I agree with all the comments about gas being the cheapest part of owning a HP boat. Every year something unexpected breaks and usually has big costs associated with the repair.
I can't imagine what your insurance will cost :eek: Unless you have a lot of cash to burn do yourself a favor and start out with something to learn on first. JMO I run a 382 with 500 EFI's and burn slightly better than 1 gallon per mile at 3800 rpm's. Good Luck with your project. |
| All times are GMT -5. The time now is 07:32 AM. |
