496 mag HOs,run better with mufflers?
I have a 2003 twin 496mag HO boat,was told they run better with a little back pressure,I have straight /empty tips on it now and need to replace them with Corsa muffler tips for noise reasons.
I was told they run better with back pressure from the mufflers,any truth to that, was anybody installed Corsa mufflers on a 496 mag HO ?and have you noticed any difference at all,good or bad? Thanks |
try something else.put some on my 496 HO (baja 272 2001)years a go lost about 10 MPHHHHHH???????and remove them the same day.i think i will try Hardin Marine Tomahawk Mufflers if they fit the transom just for the law.
Originally Posted by zx14k
(Post 3222408)
Originally Posted by boatnt
(Post 3222268)
I was told they run better with back pressure from the mufflers,any truth to that, was anybody installed Corsa mufflers on a 496 mag HO ?and have you noticed any difference at all,good or bad? Thanks I did just the opposite on my PQ...for noise reasons. Really woke up the HO's after removing the Corsa muffled tips. Didn't really notice much change at WOT, but mid range seemed better. Sounded like it anyway. |
It won't run better with mufflers. Chances are you will see a slight loss at wot.
| All times are GMT -5. The time now is 01:28 PM. |
