-   -   Missing outdrive (https://www.offshoreonly.com/forums/general-q/240768-missing-outdrive.html)
wizrd55 10-14-2010 05:45 AM
Missing outdrive
I have a320 Baja Force with a missing port sterndrive, I have no idea what I need to replace it in regards to rotation and prop
1BIGJIM 10-14-2010 06:26 AM
How does an outdrive go missing:eek:
Bravo's spin either direciton so that is not a problem. Look at your other prop to see what pitch. Its probably left hand rotation if its the port side.
What year is the boat?
I am sure you have inusrance, take it a shop and let them deal with it.
wjb21ndtown 10-14-2010 06:56 AM
Sounds like someone needed a TRS drive and didn't know where to find one. Which side of the boat was it taken from? You probably need a 1.50 gear ratio TRS drive that rotates in whatever direction relative to the side that is missing (i.e. if your port drive is missing you likely need a LH drive, or RH if stbd.). Do you have any markings from the props? If not, what motors does your boat have? I believe most of the 330hp motors came with 23p props from the factory.
