-   -   harmonics/ offshore plate/ oil cooler (https://www.offshoreonly.com/forums/general-q/241005-harmonics-offshore-plate-oil-cooler.html)
jeff1000man 10-18-2010 12:32 PM
Looking for the most accesible place to mount my coolers and they will fit beter mounting them under the front of the engine botlted to the offshore plate. This will make geting to the oil filter much easier than mounting them on the middle stringer.
I thought this morning that maybe mounting in this style will cause vibration through the offshore plate and into the cooler causing the oil to aggitate.
Any ideas on wether this will be the case or not??
I could fabricate a rubber bushing to help with this.
I also don't see that this could be any worse than mounting on the bellhousing, so maybe I don't have anything to wory about.
thumper038 10-18-2010 12:43 PM
I agree with you on the bell housing mounts.
1st Merc has mounted on the engine for years and with the black motors and they are not balanced as close as after market should be (harmonics).
2nd, under the pressure I don't believe you will aggitate the oil (no place to aggitate under the pressure).
My take :coolcowboy:
Jim
jeff1000man 10-18-2010 01:38 PM
Jim
I agree. I am going to try and mount them under the front..
jeff1000man 10-18-2010 11:43 PM
Miunted up the first one tonight. Will work on the second tomorow and post up some pics.
Actualy looks really cool in there.:coolcowboy:
RunninHotRacing163.1 10-19-2010 07:38 AM
:worthless_without_p
jeff1000man 10-19-2010 08:01 AM
http://www.offshoreonly.com/forums/n...-me-380le.html
thumper038 10-21-2010 08:06 AM
Looks cool
look us up if ya get to Loto
Jim W.
