New 548 builds, AK Racing heads >
Old 04-26-2018, 10:59 AM
Default New 548 builds, AK Racing heads
I am building a pair of new 548's for an Eliminator cat and going to use the AK Racing CNC'd heads for the first time. Standard deal 9.5-1 compression, looking for 700hp around 6000rpm. They will have Holley EFI with 2000cfm throttle bodies. As always, there has been a lot of discussion on camshaft selection. The camshafts that came out of these engines are 242/252 .640/.629 on 114 custom Comp grind. I am seriously considering reusing them as I believe that they are pretty close to what I need, but it appears that they are ground on cast iron cores, which concerns me a little. I will post head flow #s with Al's permission. If anyone has a better grind in mind, I am all ears. Engines will be dyno'd. Exhaust is the Gil offshore manifolds with 5" tails, semi dry.
snapmorgan is offline
Old 04-26-2018, 06:58 PM
Rookie's Avatar
Received 1,207 Likes on 580 Posts
How old are the cams? I'd reuse them if I knew the history of them and feel confident. What brand and what makes you think they are cast?
I'd hope he would want you to post the flow #'s, out of box and after ported. They are a tool to the whole build. Are they CNC machined? I'm also curious to the #'s, there are a few sets at the shop that are going on builds.
Rookie is offline
Old 04-26-2018, 07:57 PM
adk61's Avatar
Joe you may post numbers as you see fit... can't wait to see these rip on that dyno!!!
adk61 is offline
Old 04-26-2018, 08:05 PM
adk61's Avatar
Yes they're CNC'd and flow great for conventional 24* heads...
parts of this have been redacted due to customer confidentiality...
adk61 is offline
Old 04-26-2018, 09:17 PM
That’s a chit ton of cfms.
Baja Rooster is offline
Old 04-26-2018, 09:19 PM
They are Comp cams, have about 80 hrs on them. The cores just look like they are cast. They are much rougher than any of the steel cams that I have seen.
Old 04-26-2018, 09:20 PM
They were originally supposed to be 572's when the EFI was ordered. Holley only offers 1000 and 2000cfm. I would have liked to have about 1200.
Old 04-26-2018, 09:24 PM
I will post a pic of the cams tomorrow.
Old 04-26-2018, 09:43 PM
adk61's Avatar
Why settle for scared, when ya can be scared sh*tless!!! as my tagline states!!!
My heads aren't the cheapest out there, but they're run ready (except fitting guideplates), my heads include Comp series studs and adjustable guideplates these are necessary for perfect rocker arm tracking, so I include them.
adk61 is offline
Old 04-26-2018, 09:54 PM
with efi bigger TBs generally doesn’t hurt
hogie roll is offline
articfriends (08-07-2023), Gimme Fuel (05-01-2018)
