496 EFI to carb
Posible to go from EFI to a carb on a 496 HO mag?
$800 to reflash the computer to help with the smutty black swim platform. $800 will sure buy a nice carb, sell the ECM and it will pay for a full MSD set up. Have not looked at the gaskets to see if the EFI intake has the same lay out. |
Fixx
Originally Posted by Waterslinger
(Post 3235543)
Tank full of 87 and it is crazy smutty.
496 head will not take a carb intake see pic CRAP http://www.offshoreonly.com/classifi...o36335-en.html |
Fixx
i knew that one already:) you can have one made but by the time converting it all over and you will need a new ignition system also you may as well have it tuned..
You just need to find a dealer or Mercury service tech who can reflash your PCM to a newer calibration. Newer cals are leaner and won't soot as much on your transom.
also check fuel pressure,,,and pressuse regulator
I say leave it efi,
what year and is it a mag or a mag Ho? I have a couple 555 ecus reflashed by merc with the sooting update from 2003 496 mags ,I would sell you on for half the cost of reflashing yours. |
its a 496 MAG HO think its a 03 or 04, has aluminum manifolds
think 05 is when Merc went to cast iron manifolds right? |
| All times are GMT -5. The time now is 09:55 AM. |
