Mobil 1 Oil 15 - 40 wt
any body using Mobil 1 Oil 15 - 40 wt in trucks or heavy equiptment ? been using Rotella in the 7.3s DT -466s ,semis, 6 wheelers & heavy equipt .. Caterpillar salesman stopped in 2day and mentioned to the boyz to switch to Mobil 1 in all deisel applications thats all there using in all there equipt now ..used Mobil 1 in the V-tail Bonanza years back and lost a motor and mobil 1 bought the new motor & a few others at our local airport :eek: have had great luck with rotella in the past :drink:
[QUOTE=RunninHotRacing158;3238458 have had great luck with rotella in the past :drink:[/QUOTE]
if it ain't broke Bubba!!!!!!!!!:lolhit: |
You can't run typical automotive oils is a plane's engine.
They are two different engine applications and need two completley different additive packages. Never run airplane oil in a boat. Ken |
Originally Posted by wrinkleface
(Post 3238461)
Originally Posted by minxguy
(Post 3238664)
Airplane engines run at steady state operation and with a metallic detergent package, (as found in auto oil) you run the risk of ash build up on your plugs. If you generate enough ash your plug will foul. OK at sea level but kinda exiciting at 5,000 feet.
Aero oils have organic dertergents to prevent the ash build up, but, they do cause more engine wear which is why a plane's engine rebuils is much sooner than a cars. My 2 cents. Ken |
Fixx
i didn't know that mobile 1 made a synthetic 15w40, i know they make a syn 5w40 for trucks that worked great on the newer fords and dodges..as for regular delvac 15w40,that's all i use in the diesel trucks i work on if they dont want the synthetic oil..BTW in the winter the engines crank over allot easier with the 5w40 syn oil.
My brother owned a v-tail Bonanza. What a great aircraft. It ran circles around the Cessna 182 I was flying with almost the same engine. My understanding was that the Mobil One had a problem with the lead level in 100LL. They did step up unlike most companies.
Originally Posted by RunninHotRacing158
(Post 3238458)
Originally Posted by billeickmann
(Post 3240037)
Awesome aircraft Big daddy we left New Lenox Il and landed in Marathon fl in 6 hrs 15 mins and yes they bought a huge amount of engines 11 at our airport alone .as long as paperwork was filled out by certified aero mechanic they foot the bill .:drink: |
Originally Posted by hotjava66
(Post 3240068)
Cant hurt if you dont mind the extra cost, or use longer oil change intervals. I always use Rotella, and change at 150-200 hours. I know most of our newer equipment specs longer change intervals but in my opinion in diesels the oil gets "dirtier" faster than in gas engines, so I change more often, not worth using synthetic. If you are doing extended service intervals, the synthetic would last longer before it starts to break down, but would still get "dirty" in my opinion. I have used Mobil 1 in lots of other stuff, (besides the airplane, that gets Rotella) with no problems. This is in heavy equipment and Class 8 trucks, in the smaller diesels (7.3 or duramax) I usually go with synthetic.
sounds like i'll stick with yours and Wrinks advice IF IT AINT BROKE DONT FIX IT !!!!!! and have the boyz order out 20 cases of Rotella ..:drink: |
Oil
(Post 3238458)
U sure he was not talking about Mobil Delvac 1 5-40W, that is the diesel oil, full synthetic. We did some testing a few years ago with it. Ran a 3406E (Cat) 400,000 miles on regular Delvac 1300 15-40w, then switched to Delvac 1 5-40w. Ran the unit to 800,000 miles and tore down (this is with no interm oil changes, and filter changes at 70,000). When we miked out the componants there was "no" sign of wear on major items (ie: bearings, bridges, followers, liners). Good stuff... And I am a Shell Rotella Fan. Oh yeah most Cat oils that you buy from the dealer are bottled by Mobile. Pete |
I have run Mobil 1 in 5 of my cars/trucks (one was turbo charged) for about 350,000 total miles. Never had a problem. I even run it in the lawn mower which is now 20 years old and runs better than my neighbors new mower.
If you've been running regular oils for many miles/years then I wouldn't recommend switching. You could experience what people complain about the most...bad oil leaks. It's not the oils fault though. The natural oils seep into small leak crevaces and solidify plugging the leak. Mobil 1 will act as a solvent and wash those out opening up the leaks. I experienced this first hand when I first switched. Once the leaks were repaired my oil consumption went to zero for the next 115,000 miles. As for aircraft I thought Mobil stopped making piston aircraft grade synthetic back in the mid 80's and stayed with the turbine oils? |
| All times are GMT -5. The time now is 08:15 PM. |
