Originally Posted by Dave M
(Post 3284890)
Is that in addition to pulling the blue plastic wing nuts? It seems easy enough to do it that way.
(Post 3284980)
Interesting videos. Thanks.
I was going to send my HP500EFI headers to Teague to test and clean.....maybe not? Where are you guys located? |
(Post 3284888)
A few ???s
What's the turn around time on the testing? Are most leaks repairable? If so, what's the average repair cost? Cost is $150 area on average per header which includes a light clean up, plus transit. |
:coolcowboy:
Originally Posted by Knot 4 Me
(Post 3284989)
My guess would be the drain setup is attached to the water rail where the rear blue plastic drain plug would have resided.
Had it for two seasons now. |
So the CMI headres sold under the CMI name and not Mercury Racing name did not have the same issues?
I have a set of CMI E-Top's from around 2006 do these have issues? I'm running antifreeze in mine. |
Originally Posted by racer-x6
(Post 3285054)
Originally Posted by fountain40icbm
(Post 3285056)
No they all do.
cast aluminum manifolds
Has anyone looked into the cast aluminum Keith Eickert long tube manifolds. Reliability should be far better than any welded manifold?
Originally Posted by Tom A.
(Post 3285052)
This is a low cost insurance that water is never sitting in the headers.
What about over the winter? I ran AF w/corrosion protectors through the motor. Should i leave the AF in there? Or drain it? |
| All times are GMT -5. The time now is 05:09 PM. |
