Need to know the diff/??
Need to know the diff/ from gen 5 to 6 454 and gen 5 and 6 502 and the diff/ between tall deck and short deck blocks. And is the merc. 525 a tall or short deck block ?? thanks
I'll take a stab at this:
The 454 is a 4.25 bore, the 502 is a 4.5 bore The tall deck blocks allow for more stroke, = more torque The 525 is a 502 reg deck block Someone else may be able to explain Gen 5 and 6? The casting numbers and the block can be looked up on line for ID. |
Gen V blocks have a stamped steel timing chain cover with 10 bolts. From the factory have a flat tappet camshaft, peanut port heads. The mag engines have the rec port heads.
Gen VI blocks have a composit timing cover with 6 bolts. They have a roller cam, with vortec large oval heads on the 454. The Mag engines have the rec port heads. All of the Merc engines are standard deck height. Some of the old Merc Racing engines were tall decks. Like was said you can stroke it up to 4.375" with a tall deck. With a standard deck you can only go up to 4.25" stroke if you use offset pistons. |
now can i use a 525 intake and heads on a tall deck block, and will a 502 crank and rods work in a 454 block ,i know the pistons will not because the bore is to big.
A standard deck intake will not work on a tall deck. The crank should work.
Not to be picky:drink:, but a tall deck (10.2") can accept up to a 4.750" stroke. I don't like going over 4.5" stroke since you end up with a very short rod and steep rod angle.
The Gen VI 502 has a stock bore of 4.468" Eddie |
Originally Posted by ridefast77
(Post 3255890)
Eddie |
thanks evey one, any of you guys know where a 502 standerd bare block is laying around so one would what to get rid of i have every thing i need but the block??
(Post 3255890)
Originally Posted by Griff
(Post 3255939)
If you use the 525EFI heads, then you will have to use 525EFI exhaust. They are a modified Edelbrock head with a different exhaust bolt mount pattern.
Originally Posted by Young Performance
(Post 3255914)
With a 4.5" stroke, you can either use a 6.7 rod and a 1.25 compression height piston or you can use a 6.635 rod and a 1.27 piston. If you use a 4.625 or 4.75 stroke crank, you have to use a 6.535 rod.
You can get pistons with just about any comp. height that you can dream of. Eddie |
| All times are GMT -5. The time now is 11:32 AM. |
