Cast Aluminum Oil Pans Kiekaefer?
I have big cast Aluminum oil pans with a "K" on the side, I believe they are Kiekaefer (spelling) there is a big removable plate on the bottom with the drain plug in it. My engine builder took the plates off and now I need new gaskets. Does anyone know where to get gaskets for the plate. Or do we have to make them?
Thanks Mark |
Save time and make them, they should not be that
hard. Loy |
We use Dow Corning 732 silicone. In fact, we use it instead of a pan gasket too.
Thanks for the input. I will probably do the silicone.
Marc, How is that Cigarette project comming along? Mark |
Slooooooooooooooooooooooooooow
The best sealant I have found for this type of application is made by Toyota. Its real pricey unless you know someone at a dealership. I'm down to my last tube or I would let you have one.
Toyota part number 00295-00102. |
| All times are GMT -5. The time now is 05:37 AM. |
