525efi water temp and pressure
What temp does a 525efi normally run? It has a 165* t-stat right? My 525 was running a max of 147* according to my smartcraft gauge. All the other efi or mpi motors I've owned ran about 170* regardless of the temp of the water I'm boating in.
Also, I noticed at certain trim levels my water pressure gauge was pegged at 30 psi. Does this sound OK? |
Originally Posted by Dave M
(Post 3258656)
Also, I noticed at certain trim levels my water pressure gauge was pegged at 30 psi. Does this sound OK? Also, what variation on temp do you have running from idle to normal cruise to WOT? Same ? for pressure. |
Originally Posted by ShadBurke
(Post 3258681)
What lower unit are you running on your XR? LWP or DWP or High speed pick up thru hull? More info needed.
Also, what variation on temp do you have running from idle to normal cruise to WOT? Same ? for pressure. As far as the pressure, it seemed to vary between 25 and 30 psi at speed. This was my first outing in this boat. I don't really suspect any problems. Just trying to establish what is considered "normal". |
Dave, Where are the pics at?
Was this the boat you sea trialed at Ocean?? If so what was it?
could your thermostat be stuck open,,,causing it to run to cold,,,25 -30 water psi is what i get on my gage also
Originally Posted by fountain40icbm
(Post 3258889)
I looked over some of my old scans from my 496HO and the water pressure seemed to peak at around 23 psi and the coolant temp was usually 160-165. I'm also running a sea strainer if that matters. If the t-stat was stuck open, wouldn't it come up to temp eventually, particularly at high rpms? It seems to run great, I'm just trying to figure out what to expect with this motor. |
You will love the Best motor Mercury has built. So you bought Gary's Y2K? Didnt know it was for sale. You got a nice ride!!
(Post 3258987)
Thanks for the kind words... Sitting by the computer having sellers remourse.... Ive been staying away from the site... It still hurts....:( Perhaps another day another time...
| All times are GMT -5. The time now is 03:39 PM. |
