What fuel pump for a GenV
What is a good fuel pump for a genv that runs off of the water pump. I was looking to replace the original merc pump with a holley or something similar.
That is not the same mechanical pump as a standard Chevy pump. The arm on that pump is different than a standard pump, so you have to use a Merc. style pump. However, you can replace just the lower pump section of your existing pump. CP Performance has a real nice pump section.
http://www.cpperformance.com/p-12460...6-engines.aspx
Hope this helps.
Eddie
Hope this helps.
Eddie
I would stick with the electric Merc pump in your case. It will be much easier and cheaper in the long run to stay with the stocker. If you go aftermarket, then you will need to redo quite a bit of plumbing to make it work.
Eddie
Eddie
Hope this helps.
Eddie
Hope this helps.
Eddie
