Need Props cleaned
1 Attachment(s)
After leaving my boat in the water during Key West Run, i pulled it out and my props are almost completly covered. Any easy off items I can use to get them back. I dont really have the time to scrub them. Thanks,
I use industrial strength Toilet Bowl Cleaner or Simple Green.. Either work pretty good. Pull the prop/s off and lay in sink, spray on, rub in with your hands, let sit for a few minutes and wash off well. Do not sand or use a scotchbrite.. -Eric
Agreed.
roll off and magic erasers?
Hoosier metal polish , spray it on & polish em up
Just use some acidic type of toilet bowl cleaner or lime away.
Just about any toliet bowl cleaner. I use on the exhaust tips too.....no elbow grease at all.
I use "aluminum brightener" available from Napa, but like said
before, any acid based cleaner should work:drink: |
1% muriatic acid solution rinse off extremely well works good on hulls too just as long as they dont have zinc or copper based bottom paint
T-Bowl cleaner worked perfect. Took everything off... Spray on and rinse it right off.
| All times are GMT -5. The time now is 04:49 AM. |
