Engine driven air conditioning >
Old 12-18-2010 | 04:27 PM
Originally Posted by 36Tango
The air would be 100% when running. This is not a boat that you would anchor and sit inside. It is a V24 BatBoat
V24powerboats.com
COOL! Sounds like that type of A/C would be great for the application. The only thing I would be concerned with is compressor life at sustained high RPM.
JeremyAnderson is offline
Old 12-18-2010 | 07:24 PM
This may sound like a little redneck engineering, BUT, would if a guy were to build an aluminum enclosure with an incoming an outgoing "bung" (along with a drain for winterizing), and permanently mount an automotive condenser in in (a smaller one like found in a compavct car) inside of it. Route the incoming water from the Bravo Drive though this enclosure and then into the engine using the raw water pump on the motor. The fresh water going through the enclosure would take the heat away from the condensor. The rpm's was something that I did not think about it, but I would suspect that a larger pully on the compressor could fix that.
OK, now shoot some holes in it. Why would it not work?
36Tango is offline
Old 12-18-2010 | 09:46 PM
That really sounds like the way I would go Tango.
Old 05-30-2021 | 10:11 AM
Ttt
Did anyone come up with something for cockpit AC? like has been said the water cooled condenser is the missing link....
I've been searching but haven't found one yet.
Vintage air for vehicles has some great options with heat and AC that r reasonably priced.
delsol is offline
Old 05-30-2021 | 10:38 AM
If your engine bay is well ventilated you could probably just run a fan on the automotive condenser mounted inside the bay
sailtexas186548 is offline
