Crane Hydraulic Roller #169651
Refreshing from mechanical solid to hydraulic roller.
Combination is 572ci, 12-71, intercooler, Dart, big stellings, dominators, etc. I would appreciate comments regarding performance from anyone running this cam in a similar combination. Good choice...or..? Thank you. |
Bob @ marine kinectics
Thanks...I talked to Bob......he is the man!
Originally Posted by TX3x2gun
(Post 3280876)
Seems like a good choice. What did Bob say?
Bob's comments were all positive.
He thought a bit more lift would be the only change he would recommend, but agreed that for my use, (heavy boat, mostly cruising at 4200-4800, and no constant "hammer down" for all-out mph) the combination would work great. Maximum torque at 5600-5800 sealed the deal. No stud girdle required, no reversion. Install at 114. |
(Post 3281835)
What are the specs on this cam?
i have that cam in 4 engines,and love it.great midrange,and top end,and a sweet idle.
if you installed intake centerline at 114,you NEED to change it.put it in at 108.the lobe split is 114 ,i have the cam card,intake centerline is at 108.
Do you think that cam would be too big in a 540 n/a?
| All times are GMT -5. The time now is 06:31 PM. |
