Cheap 496 mag upgrades (375hp)
#51
#52
I've got a couple of used HO cams if anyone is interested. If you can do the labor yourself, changing the cam and a Whipple reflash is a lot of bang for the buck. I've done a lot of them, and just about any other 496 mods you can think of. Dart has just released cast iron heads for the 496. Supposed to work really well. Tyler Crocket is testing them now.
Bob Lloyd
Full Throttle Marine
Bob Lloyd
#54
Nope,just cam,reuse lifters because their roller lifters,reflash ecu,drill out idle bleed hole from 1/8 to 1/4 at throtle plate and you have a 496 mag HO,done that to my twin engine 30 foot powerquest,went from 73.9 to 80.2 gps speed.best bang for the buck
#55
#56
STOP! Don't do it. Don't go for the BS power gain claims! I spent almost $5,000 on the CMI Sportubes for my 496 HO and saw ZERO gain. If you have the early aluminum exhaust the ports are huge and it flows very well. My final decision after a lot of discussion on forums was to lose the 496 and drop in an '07 vintage 525 which I found on this site for $20,000. Seven hours of run time later I had to upgrade to a Bravo XR upper
. The cam change and ECM will get you 50 hp and a few mph. That is true. Then you will have a 496 Magnum HO. Some people are getting away with whipplecharging a stock 496 but I think you will be running on borrowed time. A shorty drive can add 2-3 mph but I'd start a thread to find out if it would be right for your application.
#57
#1 To get unbiased straight skinny regarding 496 upgrades bang for the buck call Bob Lloyd. He is my go to guy for over six years now. He can give you the answer as to what you need to get the performance you want from the hull you are running and the best package for that. As power goes up additional upgrades in the drive and/or steering can also be necessary. #2 Any custom head or throttle body porting go straight to Jim Valako. #3 Any custom cams go straight to Bob Madera of Marine Kinetics or Raylar cams if you are keeping the stock heads and valve train. #4 Dana Torque Flow exhaust is the best bang for the buck on a 496. #5 If you want 525hp out of a 496 buy the Raylar kit and change to forged pistons.
#58
Bob Lloyd
Bob Lloyd
#59
Best place to start is Bob Lloyd's Full Throttle Marine web site http://www.fullthrottlemarine.com/. Go to the "View Our High Performance Projects" and read the "496 Mag Dyno Testing & Myth Busting" article. I addition read the follow up information Bob posted on OSO, post #1 & #4 regarding the CMI Sport Tube headers: http://www.offshoreonly.com/forums/g...dyno-test.html
This guy claims a 11 mph increase and he did bottom paint at the same time.....bottom paint on a Donzi Ragazza? http://www.offshoreonly.com/forums/1887205-post7.html
Anyone considering exhaust upgrades for the 496 should read this thread, starting with post #9. Save your money for something that will really work... http://www.offshoreonly.com/forums/g...bang-buck.html
#60
I did awile back....very good read
That is my plan....BCK-106 kit, forged pistons, stock crank, Dana exhaust
