454 Gen VI, (L-29) EFI Build
Hi everyone, first post ever here.
I am building a 1999 454 EFI (L-29) MerCruiser engine for my 22' Pachanga, any advice would be greatly appreciated. First of all I am using the original L-29 heads which I understand are very limited performance wise. However I am matching the intake ports, cleaning up the pockets and the casting on the exhaust. Also plan to mill the heads .030 to help out a little with compression. The shortblock is basically rebuilt stock with Melling 777 pump. The exhaust is Eddie Marine Thunder w silent choice pipes. The camshaft is a 731 Crane hyd roller, 226/236, 587/610 I plan to have the ecm reprogramed, install an adjustable fuel regulator, and run K&N flame arrestor. My questions are, what kind of numbers can I expect with my setup? I still need hyd lifters, springs, retainers, pushrods etc., since Crane is out of business can anyone recomend the best parts or a kit that will work well with my cam? Can anyone recomend the best place to send my ECM to be reprogrammed? Is there anything lacking in my setup that I should consider that would help in performance or reliability. Thanks in advance to anyone with their input! |
Originally Posted by boatsnstuff2
(Post 3290435)
I am building a 1999 454 EFI (L-29) MerCruiser engine for my 22' Pachanga, any advice would be greatly appreciated. First of all I am using the original L-29 heads which I understand are very limited performance wise. However I am matching the intake ports, cleaning up the pockets and the casting on the exhaust. Also plan to mill the heads .030 to help out a little with compression. The shortblock is basically rebuilt stock with Melling 777 pump. The exhaust is Eddie Marine Thunder w silent choice pipes. The camshaft is a 731 Crane hyd roller, 226/236, 587/610 I plan to have the ecm reprogramed, install an adjustable fuel regulator, and run K&N flame arrestor. My questions are, what kind of numbers can I expect with my setup? I still need hyd lifters, springs, retainers, pushrods etc., since Crane is out of business can anyone recomend the best parts or a kit that will work well with my cam? Can anyone recomend the best place to send my ECM to be reprogrammed? Is there anything lacking in my setup that I should consider that would help in performance or reliability. Thanks in advance to anyone with their input! Be sure to upgrade the oil cooler and lines, keep in mind you have cast internals so that limits what you can do. |
There may be a reversion issue there? When I asked about that cam w/ my 496 manifolds & captains call I was advised against it. Your Eddie Marines & silent choice may be OK but you should double check.
Originally Posted by jeffswav
(Post 3290631)
Those are large ovals, for what you are doing the heads will work. I use the moral lifter and isky springs. Your weak link will be the intake. Should see about 450HP give or take.
Originally Posted by Itsallgood995
(Post 3291015)
What is the lobe separation angle of the camshaft. If you can post the cam timing at .006 lift from the cam card.
Originally Posted by Boat1
(Post 3291047)
Do you already have the cam? You could sell your silent choice setup and get long risers for your manifolds.
(Post 3291235)
Maybe, I am not a expert just somone that has had a lot of trial and error. LOL I had reversion on a setup several years ago. I had a flat tappet cam with similar duration specs and stock exhaust/silent choice. The engine had moisture under the valve covers, behind the timing chain and ruined the oil. Before I knew it I had damaged the mains and broke the crank shaft. Mine is loud all the time, just turn up the stereo. You could get mufflers on the tips.
| All times are GMT -5. The time now is 06:51 PM. |
