Cant find info on my boat. 87 Nova spyder
Hello all,
This is my first boat. I picked up an 87 26ft Wellcraft Nova spyder with one 454 Mag and a Alpha one drive. The boat is clean and was just under 500 hours. It runs good with no problems. It has a SS 19pitch prop. The boat seems to be very good on lake Erie. Im not sure where to find Motor specs, HP rating. What heads are on it or what the cam specs are. I dont know if its worth puting a Cam and intake on this boat or just running it the way it is. Has any one had any luck or done any work to one of these? thanks Gene |
Originally Posted by buddy1k
(Post 3302943)
Hello all,
With an Alpha lower, I would not build that engine at all. You will end up buying a new lower unit.
Thanks guys..
Would it be worht it to put a bravo in it? |
(Post 3302968)
Thanks guys..
I believe the 1987 model year 454 mag with the alpha was 330HP. Where in 1988, the 454 mag/bravo combo became the 365HP 454, with forged internals, rect port heads, etc.
I had a 1987 Four Winns Liberator. Boat was a 350 mag/alpha combo. Ended up becoming a 540ci, bravo boat. 50mph top speed to 72mph. Enjoy it for what it is. Great boat, but you'll never recoup any money you invest in it. The engine you have isnt upgradeable very much, without spending alot of money. Your engines probably have the small peanut port heads, cast cranks, cast pistons, iron intake manifold, etc. Going to a cam, intake, and exhaust manifolds might help a little. But its a heavy boat for a single alpha. |
Mild,
Thanks for the info. I will have fun with it |
| All times are GMT -5. The time now is 03:06 AM. |
