Edelbrock carb
Anybody running an ebrock carb? I have a 88 rinker 206 with a new longblock going in 350ci, and i'm going from the 320 efi setup to an ebrock aluminum intake and carb. should I be looking at 600 or 750 cfm? anyone with similar setup?
I run a pair of them on my 454's in my gibson, work very well, I only run the 600's as the engines never see 4000, if you turn the normal 44-4600 run the 750's
Thats good to hear, hows tuning? easier than Holley?
I run Edelbrock on all of my motors. Easier to tune, tougher all around, no joints below the fuel level, simple rebuilds.
so I'm guessing the 600 cfm would be best for otherwise stock 350 ci?
600 is plenty for 350. I have used them on small blocks they work well, make sure you get the marine version.
Yes I am aware thanks.
Originally Posted by 88 206
(Post 3306828)
I also run Edelbrock 1409 on my 350 89 Wellcraft. No issues easy to work on and hassle free.
Might add to get the needle kit as it makes it easy to change out the fueling. I have the 1410/750cfm. I don't think it's enough for my 509.
You can never have enough fuel unless you're on fire. |
| All times are GMT -5. The time now is 03:48 AM. |
